It is currently Tue Aug 05, 2025 6:55 am
PostPosted: Sun Jan 04, 2015 7:18 pm
Hi all,
I'm reconditioning the rear hubs and there's an item in the Timken roller bearing that I am not sure about.
See below pic - there are the two roller bearings and races, the dust seal, a split pin. But there is also a slim round rubber seal. I'm not sure how it fits in the hub. Any directions would be greatly appreciated please!
PostPosted: Sun Jan 04, 2015 7:50 pm
It's an O-ring, I believe it goes onto the shaft first, before the bearings do.
PostPosted: Sun Jan 04, 2015 8:02 pm
Thanks for the reply. Sorry, I'm not sure I catch your drift.
I have installed the bearing races and bearings into the hub assembly. Then this complete hub needs to be mounted onto the stub axle.
So the bearings don't really go onto a shaft as such when they are first installed. Do you mean I need to put the o-ring onto the stub axle before I mount the hub and torque it up with the castle nut?
I'm sure you're right, I'm just checking to make sure I understand it correctly.
PostPosted: Sun Jan 04, 2015 9:21 pm
Thats how I read the Docs responce. O ring on the stub first, then hub assembly.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jan 04, 2015 9:24 pm
Cool, thanks both of you!
PostPosted: Sun Jan 04, 2015 9:37 pm
Yes that ^^^ is correct.
Hint:
If the roller bearings bind a bit when torqued up, back the nut off to the next pin hole. Otherwise you will `brinell' the bearings.
The rear bearing setup is similar to the front wheel hub on say a Holden, there is no operational reason why it has to be `torqued up' like Mini front hubs do, [edit] when tapered roller bearings are fitted].
There is no drive torque transmitted through it.
Last edited by drmini in aust on Mon Jan 05, 2015 7:32 am, edited 1 time in total.
PostPosted: Sun Jan 04, 2015 10:06 pm
Thanks Doc for confirming that. And also for confirming what I'd read; that these don't need the old torque like the original ones, so I'll tighten these like other cars I've had as you described.
This forum is a great resource for me doing my rebuild.
Users browsing this forum: Bing [Bot] and 120 guests
