It is currently Wed Jul 23, 2025 8:24 am
PostPosted: Sat Feb 28, 2015 8:59 pm
Looks like it's almost riding on the bumpstops. I'm new to minis, so not sure what is normal..
Attached is a picture of it at ride height.
PostPosted: Sat Feb 28, 2015 9:07 pm
Yes. What pressure do you have them at?
So... I'm Seifer
PostPosted: Sat Feb 28, 2015 9:19 pm
Yes definately too low.
If your in perth I can pump up for you.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sat Feb 28, 2015 9:46 pm
Rodney
Sweet, I'll take you up on that.
I'll PM you when it's drivable again.
PostPosted: Sun Mar 01, 2015 3:34 pm
They handle unreal when on the bump stops :D .....just snap the wheel studs off when you do that though :(
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Mar 01, 2015 4:55 pm
I's say it's just right - if anything go lower!
:D
PostPosted: Sun Mar 01, 2015 5:33 pm
So does the photo that alexw posted depict any other suspension problems or does it indicate only that the hydro pressure is too low?
PostPosted: Sun Mar 01, 2015 6:15 pm
Needs a grease, the ball joints might be worn.
The brake hose looks old.
PostPosted: Sun Mar 01, 2015 7:07 pm
If your nor I can pump them up or boomini is sor
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Mar 02, 2015 9:26 am
If you've been driving around for a while like that and you have rubber uni's then I suspect they will be close to giving up as well.
So... I'm Seifer
PostPosted: Tue Mar 03, 2015 9:11 am
I would have a serious look at the ball and cups. My guess is the ball could have worn through the plastic cup and collapsed into the top arm which would drop it even lower.
PostPosted: Tue Mar 03, 2015 9:31 am
Thanks blokes. I'll take it to boomini when it's back together. Wife wants to paint everything!!
PostPosted: Tue Mar 03, 2015 1:23 pm
Lucky man, all my wife wants to paint is the bathroom, kitchen or her nails...
Keels.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
Users browsing this forum: drmini in aust and 77 guests
