It is currently Thu Jul 17, 2025 8:02 pm
PostPosted: Sat Mar 07, 2015 8:02 am
Just got back from a week in Melbourne and Barney will not fire. Spins well, but not even a hint of a kick. Plenty of charge. Any tips on where to look first?
PostPosted: Sat Mar 07, 2015 8:22 am
Probably just sulking because you went away without him...wash and polish him then try again :|
PostPosted: Sat Mar 07, 2015 9:53 am
Still sulking. Anything obvious apart from coil lead and condensation in the dizzy cap?
PostPosted: Sat Mar 07, 2015 10:09 am
Fuel? Spark?
PostPosted: Sat Mar 07, 2015 2:44 pm
Zero spark. Ideas? I put an electronic module in the dizzy a while back and a few weeks ago it had a long miss, like fuel delivery failure.
PostPosted: Sat Mar 07, 2015 4:16 pm
have you tried changing the condensor?
(\_/)
(O.o) <CoPy> <) MaY oBtAiN wOrLd DoMiNaTiOn.
PostPosted: Sat Mar 07, 2015 5:50 pm
Have you got a points dizzy lying around you can try? Easiest way to find out if the electronic module has gone t!ts up.
Got a multimeter? Just do a few voltage checks, make sure the coil is getting 12V etc.
cheers,
Jacob
PostPosted: Sat Mar 07, 2015 8:07 pm
Buy a Ford :)
PostPosted: Sat Mar 07, 2015 9:26 pm
Monte wrote:
Buy a Ford :)
Doesn't Barney already have the oval bonnet badge
PostPosted: Mon Mar 09, 2015 2:28 pm
I don't have a multimeter. Spewing!
PostPosted: Mon Mar 09, 2015 5:23 pm
A huge $19 and you're away... might as well, they're handy for all sorts of stuff
http://www.supercheapauto.com.au/online ... mendations
cheers,
Jacob
PostPosted: Mon Mar 09, 2015 5:54 pm
PM sent.
PostPosted: Mon Mar 09, 2015 7:25 pm
Try pulling the Choke!
"Let us remove your "SHORTS"
PostPosted: Mon Mar 09, 2015 7:39 pm
Weber. No choke. More importantly, no spark.
PostPosted: Mon Mar 09, 2015 8:08 pm
Have you got a test light Evan , next best thing , Ignition switch hasn't sh!t all of a sudden :idea:
