It is currently Sat Jul 19, 2025 3:45 am
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
 Post subject: Re: Front Seat Re-Trim
PostPosted: Mon Mar 16, 2015 2:18 pm
Thought this drawing showing the configuration of the Mark 1 Mini seats might be of interest.
The rubber seat platform (also called flexolator and diaphragm in some documents) has a UK part number but the later MK II Series seats used an Australian produced part.
Producing these drawings is what phillb's Dad did for a living back in the day when he worked for BMC/Leyland. Unfortunately, Phill, this one was drawn and checked by other draughtsmen.
PostPosted: Thu Mar 19, 2015 7:53 pm
OK got the chairs stripped down by the upholsterer. Im going to get the frames blasted and powder coated.
It would appear that the seat springs have been played with at some stage of these chairs life????
How should they be attached???
It sort of appears that some of the springs are pointing upward, and I did notice that the seat foam on one chair appeared to have a rise in it????? Could this have been caused by the spings pushing upwards?
Can anyone advise how these springs should be attached?
Also.... the rubber cap on the seat adjuster, Id like to get that off before they go for blasting etc... any tips on how I could do this??? Maybe hair dryer to soften it up a bit??
And what colour do people think I should do these seats???? Currently Ive got Red Sparco Sprints in the front and the rear seat is trimmed with black vinyl but the portion of the rear seat where you sit, it red vinyl....
Im thinking just doing all the seats black vinyl with black cloth insert where you sit???? My old man reckons to go red cloth......? That might be a bit to lolly?
You can kind of see here what Im talking about with the seat base pushing upwards?
PostPosted: Thu Mar 19, 2015 8:26 pm
Those springs look like they were taken out of a lounge chair.
PostPosted: Thu Mar 19, 2015 8:59 pm
Hmmm. So sounds like someone has done the dodgy at some stage????
What can I do to fix this???
Can I fit this kit instead??? Will it fit this frame??
http://minisport.com.au/mini-rubber-sea ... all-models
PostPosted: Thu Mar 19, 2015 9:06 pm
Yes as the holes are already there. That's what is mine.
67 Deluxe under going full resto
PostPosted: Thu Mar 19, 2015 9:12 pm
Ok cool. I'll order a pair of them. How many of the little steel clips are there that hold the vinyl to the chair??? Thinking I should get a few new ones of them to???
PostPosted: Thu Mar 19, 2015 9:20 pm
Enough to fit them when you order. You also need the spring section that runs up the back of the car. I got those from minispares.com as I couldn't find the in oz.
I am going to get seat foam from these folks. Called them and these said they had a trimmer on site and can cut foam to size if you have the old foam. http://www.luxafoamnorth.com.au rough price for two sections for you bum was $20.
PostPosted: Thu Mar 19, 2015 9:22 pm
Those frames look ok. I wouldn't blast if they are ok. I got acetone onto mine and a bit of elbow grease and rubber bit for my angle grinder and they came up great. Cleaned any metal exposed with rust converter and sprayed in satin black.
PostPosted: Thu Mar 19, 2015 9:30 pm
I'll get the upholsterer to make up some new foam. I'm not sure what condition the rear back spring is in?? I never got to see it??? I would hope it's actually there......
I'm mainly going to get the legs blasted and power coated. They are a bit rusty.
PostPosted: Fri Mar 20, 2015 6:07 am
If they are gone here it the replacement http://minispares.com/product/Classic/Interior/C708.aspx?17&ReturnUrl=/search/classic/squab.aspx|Back%20to%20search
PostPosted: Fri Mar 20, 2015 3:06 pm
OK so the upholster reckons the foam is pretty sh ithouse. And he suggested that I source that instead of them trying to make something up...
So it seems that I need:
Back section internal spring
http://www.minispares.com/product/Class ... 0to%20shop
Back section foam:
Bottom rubber mat/spring
Bottom foam
And some trim clips, but Im not sure how many???
PostPosted: Fri Mar 20, 2015 4:04 pm
I'm tempted to re do mine. The supports are fine. but the vinyl is torn. Was quoted 950$ to do a pair.
for a little more I could go cobra low backs lol
PostPosted: Fri Mar 20, 2015 4:21 pm
To re-do my Torana seats front and rear cost me $1500, I supplied the NOS Nylex Long Grain Vinyl and NOS Cloth insert, which cost me $1000.....
PostPosted: Fri Mar 20, 2015 6:38 pm
These chairs also have a different back setup....?
It has 4 of these straps with two hooks at either end which go across the back frame. One is broken.... I can't see the anywhere for sale?? Man these seats are a friggen odd ball.....!
PostPosted: Fri Mar 20, 2015 6:44 pm
Mine had the same but old and shagged.
