It is currently Tue Jul 22, 2025 7:52 pm
 Post subject: Rear Brake Drum AYA4020
PostPosted: Mon Apr 13, 2015 8:57 pm
Does anyone recognise the part number AYA4020 Mowog brake drum.
It measures 180mm across so it appears to be the same as the std 21A22 drum.
PostPosted: Mon Apr 13, 2015 9:02 pm
MG midget maybe??
PostPosted: Mon Apr 13, 2015 9:03 pm
AYA4020 is an Australian part number and is listed in some Australian Mini parts books.
21A22 is a UK number.
This probably means they were getting brake drums made locally.
PostPosted: Mon Apr 13, 2015 9:12 pm
Thanks, That's what I needed to know. All good - I will put it back on.
PostPosted: Mon Apr 13, 2015 9:36 pm
As mentioned above, it's the Australian produced version of the standard Mini (i.e. non-Cooper S) brake drum. First released into production in May 1963, so they must've used the UK part until then. You may find the casting date code on there too.
PostPosted: Mon Apr 13, 2015 10:10 pm
AYA4020 listed in Mini K book PUB1038 (final).
