It is currently Thu Jul 03, 2025 10:16 pm
PostPosted: Mon Apr 20, 2015 8:13 pm
I will have to go and check mine now.
Phil 850
How high are your revs in 4th at 100kph? My revs are 4500rpm at 100kph.
PostPosted: Mon Apr 20, 2015 10:30 pm
I don't have a tachometer hence the measurement method used to find out the ratio.
By calculation from a 3.44 diff providing 25.7 kph/1000rpm you get at 100 kph:-
2.9:1. 3280 rpm
3.1:1. 3506rpm
3.44:1. 3891 rpm
3.65:1. 4129 rpm
3.765:1 4259 rpm
4.13:1. 4672 rpm
I have only once done 100kph and the engine sounded like it was screaming so that's why I investigated what diff it had.
PostPosted: Mon Apr 20, 2015 10:51 pm
Looks like I may have a 4.1 diff as well. Starts getting noisy at 80kph.
But mine has other issues. The muffler looks like it has been burnt so maybe someone has taken to the baffles with a gas axe. Might download one of those noise meters and see what it is.
PostPosted: Tue Apr 21, 2015 7:56 am
@ 100kmh (actual) GPS speed with my 3.647 diff and 10" A008s, I'm doing almost 4,400rpm.
PostPosted: Tue Apr 21, 2015 7:12 pm
I used the data for the 3.44 cooper diff in the Orange mini manual.
I then just calculated what the other ratios would come out at. It may not be perfect but should be very close.
PostPosted: Tue Apr 21, 2015 8:30 pm
Now we need to add the recommended BHP to pull each diff with say 10" control wheels :D
PostPosted: Tue Apr 21, 2015 9:03 pm
Out of curiosity, what is the maximum you would normally rev a relatively standard 1100 or 1275 to.
I'm wondering how close to running out of performance/revs those of us with low ratio diffs are ?
PostPosted: Wed Apr 22, 2015 7:52 am
A standard 1098 will be out of puff by 5500rpm or earlier and around 6500 for a 1275.
PostPosted: Wed Apr 22, 2015 8:14 am
A stock Cooper S or Oz GT will rev to 6500 (downhill in 4th), but a stock Morris 1100S or 1275LS motor will die in the bum long before that- over 5500 is a waste of time (in the gears). :lol:
Users browsing this forum: Bing [Bot], Pottsy and 94 guests
