It is currently Fri Jul 18, 2025 3:09 pm
PostPosted: Wed Apr 22, 2015 3:58 pm
sounds great goes well also came on a run with vmci to korumburra
65 panel van Sprog
73 panel van Iggy
PostPosted: Thu Apr 23, 2015 5:23 pm
I use the same box setup as the Porsche guy but use swivel turntables and a Dunlop camber/castor gauge setup as it also gives a KPI check. It is important to make sure you are doing it on a level floor, so packing under the tyres/ turntables may be necessary. Also use a corner weight system too, which is the first step prior to doing the wheel align.
1962 Mini Speed sports sedan
PostPosted: Sat Apr 25, 2015 11:15 am
Any good ideas on a cheap and easy corner weight system to use
PostPosted: Sat Apr 25, 2015 11:26 am
Flat road and a brake pedal. Whichever wheel locks first is the lightest.
It doesn't get any cheaper than that.
I know it will get ridiculed but that advice come from Ron Tauranac. :lol:
PostPosted: Sat Apr 25, 2015 1:22 pm
Keith Calver has a pretty good system he uses - you just need a mini clutch slave cylinder, a pressure gauge, and some scrap metal to knock one up. Detailed here http://www.calverst.com/articles/SUS-Suspension-Corner_weights_and_bump_steer_basics.htm
PostPosted: Sat Apr 25, 2015 5:11 pm
Way back in the 80s when I worked on Formula Pacific Ralts we used a similar device that used an old style pointing tension wrench as lever and gauge.
PostPosted: Sat Apr 25, 2015 8:19 pm
That sounds like an excellent idea :D would be easier to rig up for sure.
