It is currently Sat Jul 19, 2025 6:13 am
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Front Seat Re-Trim
PostPosted: Sat May 09, 2015 8:59 am
niffty64 wrote:
this what mine look like from newton commercial
Thanks for that. Can I please ask you to measure from the back edge of bolstered bit at the front base of the chair to your back rest. It just looks like u have heaps of bum space with that seat.
PostPosted: Sat May 09, 2015 4:45 pm
phillb wrote:
My seat bases are 440mm from the front edge to the backrest and approx 220mm from the floor to the top of the base of the seat. How do these measurements compare to yours.
Ok. Got some measurements.
From the bulging lower section of the seat back Seat back to front most piping of the base is 380mm.....
From right under the seat back at its most visible section to the front most piping of the base is 400mm
Seat base height at rear of base is 220mm
The carpet underlay is 10mm thick
Total height from the floor to the top of the backrest is 650mm
The backrest is tooooo thick...... And hats their fault. So maybe just maybe they can change that. I'll chop some underlay out and maybe that will work? Otherwise, I'll pay to get the foam base thickness reduced.
PostPosted: Sat May 09, 2015 4:50 pm
PostPosted: Sat May 09, 2015 6:57 pm
will try to get some measurement 2morrow.
I know it can be so frustrating when you do all the investigation as you did, but there are so many variables working with old cars.
I've had so many "redo's" in my resto
PostPosted: Sat May 09, 2015 7:44 pm
Here is my Mk 1 seats Brad yours are way to fat on the backs and the bases
Brad they are fatter then my Rover Cooper seats
PostPosted: Sun May 10, 2015 2:05 pm
When you say fatter then your Rover seats, do you mean the basses are fatter or the backs are fatter? Or both?
PostPosted: Sun May 10, 2015 2:33 pm
this photo is from the bottom of rear squab
this one is touching the roof liner to where rear squab and seat base meet
this obviously is rear squab to the floor at seat mounts
hope it helps
PostPosted: Sun May 10, 2015 4:15 pm
Wow. That's great mate. Massive difference in size there!!! I'll print those out and supply the upholster.
PostPosted: Sun May 10, 2015 5:14 pm
just noticed the headliner picture upside down but you get the idea.
PostPosted: Sun May 10, 2015 5:18 pm
Ah ha. Cool. Makes sense now!
PostPosted: Sun May 10, 2015 7:55 pm
Ok comparo time.
Look at how thick the back rest is. 110mm
PostPosted: Mon May 11, 2015 7:36 am
Hard to see in that above pic of the backrest, but the 0 mark is lined up with the bulged out section of the backrest, it extends further then just the piping.
PostPosted: Mon May 11, 2015 7:35 pm
Seats back at the upholsterers. They said it originally had 1 inch thick foam in the base, but I had supplied them with 2 inch thick base foam which minispares supplied... So that's my stuff up. After looking at the above photos they agree the back is to thick. It's also got 2 inch thick foam in the back as well. Anyways, we will work together to get it sorted out.
Should I also keep the front bolstered section????
PostPosted: Wed May 13, 2015 12:40 pm
Just bought a set of these seat extenders, do these work ok at moving the seat rearward?
http://www.minispares.com/product/Class ... 0to%20shop
PostPosted: Wed May 13, 2015 1:31 pm
Sort of. They let you put the seat further back, but they do raise up the front of the seat in doing so. They are also a bit dodgy. Instead of having the front 'leg' of the seat pinched between two sheet metal supports, it is now bolted to the side of the extender bracket, which is itself held at the front. Its not an elegant engineering solution, I doubt its as rigid as the original, and I suspect wouldn't be strictly legal.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Users browsing this forum: Majestic-12 [Bot] and 101 guests
