It is currently Thu Jul 24, 2025 5:28 am
 Post subject: HS4 carbies
PostPosted: Mon Jun 08, 2015 9:54 pm
Hi
I am fitting a pair of new HS4 carbies to my car and I see they have the floating type needle.
Can I or should I convert them over to the fixed type needle and if so what parts do I need to do so
and where is the best place to buy them
Cheers and thanks in advance
 Post subject: Re: HS4 carbies
PostPosted: Mon Jun 08, 2015 10:11 pm
$7 from miniking http://minikingdomonline.com.au/product ... rsion-kit/
or $20 from minisport SA http://minisport.com.au/su-needle-conve ... xed-needle
PostPosted: Tue Jun 09, 2015 11:24 am
Thanks Simon
Will I need new needles
PostPosted: Tue Jun 09, 2015 12:17 pm
not necessarily - the little retaining collar on the springy needles comes off pretty easily, so you can put them in the converter adapters, but you might find they're worn from rubbing against the jets.
otherwise, you can use my SU needle thingy to find equivalent fixed needles. Springy needles have a 3 letter code, fixed needles have a 1-2 digit plus number code.
http://www.morrismini.com/suneedlesv2.aspx
what needles do you have now?
PostPosted: Tue Jun 09, 2015 1:33 pm
Needles is needles....
If the needle profile you need comes in a fixed type needle it fits straight in. If its a swinging needle then you fit it using the little adaptor....
The trick is finding what profile you need, either "kind" of needle will fit in your carbs..
Cheers, Ian
PostPosted: Tue Jun 09, 2015 7:23 pm
carbies are brand new and needles are AAK so I will just be using these as a starting point anyway
I need to buy a couple of ram-flow filters and assume that I probably need the offset ones ??
Cheers and thanks
PostPosted: Tue Jun 09, 2015 8:35 pm
yeah, but they're no good unless you put some proper filter elements in them. Though I got some really nice ones from Midel that take a standard type 5" paper filter
PostPosted: Tue Jun 09, 2015 10:33 pm
I run an oiled Unifilter foam pad in my Ramflo and I find when I wash it out that it does pick a lot of stuff up. They flow better than the Lynx foam. But I'd not use them on a rally car.
