It is currently Sat Jul 19, 2025 5:36 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 1979 Aussie mini
PostPosted: Sun Jun 21, 2015 8:35 pm
This discussion reminded me of this thread - viewtopic.php?f=2&t=85906&
Also, whilst the image below is of a seat belt mounting point test that involved a pneumatic ram pulling the B pillar mounting point inwards it does show the performance of the door closing mechanism and hinges that kept the door in the closed position. So it's quite possible the Australian Mini door met all the relevant ADR's at that time.
PostPosted: Sun Jun 21, 2015 9:16 pm
Rover Cooper
mine has the front and rear inertia seat belts, side intrusion bars and the brake light fitted, but then its a complied import done about 6 years ago in Adelaide and easily changed over to Vic rego now its on club plates.
PostPosted: Sun Jun 21, 2015 9:35 pm
michaelb wrote:
I have a 1978 1275LS and it had no side intrusion bars in the doors.
It does have handbrake warning light and brake fail light which I have reconnected in the rebuilt car.
I don't think I found child restraint anchors either
No bars in mine either.
The lights were in the dash above the instrument cluster.
There are captive nuts on mine.
Hey Michael, any recent photos of your car? It's a gem I reckon. I'll be interested to see if the Binky car surpasses it in terms of finish..
Alec
PostPosted: Mon Jun 22, 2015 4:23 pm
My '79 leyland has no bars. Does have the handbrake light and brake fail light too (although the brake fail is now a 'low brake fluid' light).
I think it has captive nuts too, with a plate welded to the parcel shelf to spread the load.
PostPosted: Mon Jun 22, 2015 9:19 pm
+1 as above Aug 78 1275 LS XNFAD18Y / 103724 ( nice sig 1275LS :wink: )
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Sat Jun 27, 2015 8:49 pm
Where does the 'brake fail' light fault come from?
PostPosted: Sat Jun 27, 2015 9:02 pm
In the body of the master cylinder is a switch that will activate if there is a pressure differential from one of the brake circuits.
PostPosted: Sat Jun 27, 2015 9:03 pm
The dual circuit master cylinder turns on the light when one circuit fails.
PostPosted: Sun Jun 28, 2015 4:37 pm
Great info. Thanks guys.
Eiles
PostPosted: Tue Jun 30, 2015 10:28 pm
Does anyone in sydney have compliant internal hinge doors on there car?
It's nice to be important, but it's more important to be nice.
1979 998cc Leyland Roundnose Irish Mini
PostPosted: Sat Jul 04, 2015 12:42 pm
This is one of the late dash tops
PostPosted: Tue Jul 07, 2015 7:32 pm
I have found out what needs to be done and it costs $1300. That's why I'm asking if anyone has a mini with internal hinges that has compliance.
PostPosted: Wed Jul 08, 2015 6:14 pm
I would suggest this is a somewhat irrelevant question....
I think you'll find that pretty much all Mins that have been "complianced" (other than Oz minis issued with a compliance plate at the factory) have internal hinges - and, indeed, the exact same hinges your car will have. (So the obvious answer is - yes).
The point is whether the compliancing officer will sign your paperwork based on what you have.
Many ADRs (brake lines are one example) allow (Aus) compliance to be demonstrated by showing that the item meets the relevant international standards; ie British Standard/MILSPEC etc .
Cheers, Ian
PostPosted: Thu Jul 09, 2015 10:58 am
Cheers, Ian
As Ian has said, all Rover minis complied in Australia would have the same hinges as yours.
Have you talked to these guys yet? They do import compliance for Japanese cars
http://www.ozcooper.com.au/
PostPosted: Sat Jul 11, 2015 5:03 pm
I have talked to them. I just want to talk to someone who has got a uk/Irish car through the compliance.
