It is currently Sat Jul 19, 2025 3:57 am
PostPosted: Sun May 22, 2005 12:22 am
Spaceboy, was that you on Saturday arvo around 1.30pm heading south on South Road in a lime green clubby?? Chick in passenger seat... :wink:
If it wasnt, you have a twin who drives a green clubby. Definately looked like you, but you have a red clubby.....
PostPosted: Sun May 22, 2005 1:02 am
Yeah i saw him at brickworx too.
With a lady.
Who is the lady?
PostPosted: Sun May 22, 2005 12:51 pm
teehee Yes the guy was Spaceboy, and the chick was me, and the Mini was mine :D We were down at Brickworx getting a new oil filter to service my Mini
PostPosted: Mon May 23, 2005 12:14 am
Ahhhhhhh.... I was going to say it looked like you in the passenger seat... and it looked like your car.... but i thought you would have more sense than to hang around Ryan :roll: so I assumed it couldnt be you..
its a joke....
PostPosted: Tue May 24, 2005 9:30 pm
I saw them as well on south road
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue May 24, 2005 9:47 pm
:shock: Ya kidding right? :shock:
PostPosted: Wed May 25, 2005 4:15 pm
who's kidding about what big Willeh? and i know it was a joke Supercharged 850 :P But who else is gonna fix my Mini free of charge muahaha ;)
PostPosted: Wed May 25, 2005 9:33 pm
well its not like i don't get anything in return :D
PostPosted: Wed May 25, 2005 11:58 pm
Ok so i gather that:
Spaceboy is dating KittyKat? yeah?
Or at the time of that last message anyway.
yinno how relationships are.
kids :roll: :lol:
PostPosted: Thu May 26, 2005 12:15 am
so's i was driving the kittykat special today to tafe, and it topped out at 125 downhill and buffeted around by crosswinds on the southern expressway..
with the speedo needle jumping about all crazy like.
so's then i go to the racer's edge and i'm all like
"i need nos.. lets make it 2 of the big ones.. and i harry.... need it by tonight"
PostPosted: Fri May 27, 2005 4:51 pm
"YOU'LL BLOW URSELF TO BITS!!?!?"
"tuna sandwich minus the crusts"
"OMGBBQ my floor pan is unbolting because of high speeds!!!!"
..that movie makes me laugh :lol:
PostPosted: Sat May 28, 2005 2:42 am
'I'll race you for slips"
For some of us, the only slip we have is CLUTCH slip :lol:
PostPosted: Sat May 28, 2005 11:53 am
ns clutch slip
5 grand drop the clutch and it slipped through first, second, third, and forth so i had to back off the throttle to take off the line :oops:
so much for a brand new clutch.. can i adjust the clutch in anyway..?
PostPosted: Sun May 29, 2005 12:41 am
dr trim wrote:
ns clutch slip....... can i adjust the clutch in anyway..?
Yep, it's a cable operated clutch.... there should be some adjustment nuts (on the threaded cable end) around the clutch arm above the gearbox.
You might find that your new clutch has bedded in and is now not reaching the flywheel. In this case, you would need to make the outer casing shorter by winding the nuts further up the cable (and therefore allowing the pressure plate to move closer to the flywheel.)
The idea is to have a very slight amount of slack in the cable when your foot is off the pedal. This will remove pressure from your thrust bearing and put all the pressure on the friction plate - if it still slips, the clutch itself is stuffed. Too much slack in the cable, and your clutch will not disengage properly, making gear changing impossible without a bit of grinding.
PS... supercharged engine - 1800rpm, drop the clutch, then ROCKET away without wheelspin :wink:
PostPosted: Sun May 29, 2005 3:33 am
speaking of clutch, my clutch starts to crap itself days before the cruise!
the hydraulics that is.. cos it's a new borg and beck heavy duty clutchamaroo
