It is currently Sat Jul 26, 2025 10:30 pm
PostPosted: Mon Aug 17, 2015 10:47 pm
Back in the 60s, with an A series they reckoned on 10psi per 1000 rpm if you wanted the bearings to last.
So I only need 50 and not 100. :mrgreen:
PostPosted: Tue Aug 18, 2015 9:24 am
She won't rev past 5 :?: Get it balanced and it will spin like a top :lol:
PostPosted: Tue Aug 18, 2015 9:35 am
It will rev higher but there is no need.
PostPosted: Tue Aug 18, 2015 9:51 am
as for the 10psi per 1000 rpm - I think it was Smokey Yunick talking in relation to small block chevs or NASCAR motors - one or the other.
PostPosted: Tue Aug 18, 2015 10:55 am
Once you get beyond 100psi you are starting to test the spin-on oil filters. They start blow the seal out at those sort of pressures.
PostPosted: Thu Aug 20, 2015 1:00 pm
Ive kept an eye on the oil pressure for the last few days and it starts on about 80 when cold then fluctuates between 50 and 75 when up to temp. 50 when sitting at the lights then goes up to 75 when driving. From what ive read online It appears that this is normal for a car but i havent found anything specific for minis.
PostPosted: Thu Aug 20, 2015 4:25 pm
This time of year, those numbers are normal.
Idle pressure will drop a bit in Summer, that's normal too.
PostPosted: Sat Aug 22, 2015 1:57 pm
Thanks for your help, i certainly puts the mind at ease
PostPosted: Sat Aug 22, 2015 2:43 pm
Everyone misses their oil pressure once its gone...
Like the inverse of age. At 75 we dream of 20.
