It is currently Sat Jul 19, 2025 5:03 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Oil cooler
PostPosted: Tue Aug 25, 2015 12:28 pm
When I had my Cooper in 1963 the oil temp was one thing that many people felt was a problem as it was going to get too hot and not lubricate properly as the oil was going break down quickly. Being a person who had to know what was happening I ended up fitting a temp sender unit in the in/out union to the filter (which ever it is) on the front of the engine and then put in another temp gauge same as the water temp gauge. I found that the oil temp never got above about half the water temp even on the hottest of days, so I was satisfied that there was no problem and left it at that. Just my observations from a long time ago.
Graham
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Tue Aug 25, 2015 12:50 pm
simon k wrote:
phillb wrote:
So is there meant to be support brackets going down to the lower edge of the valance? Mine is just mounted on the folded section using 2 of the 4 screws on the base of the cooler.
yep - something like this: https://www.minispares.com/product/Clas ... A1794.aspx
they fit with the long flat facing forwards, inside the beaver panel. Mine (originals) have a double layer on the rearward half of the short flat and the forward half as a single layer. The forward half sits under the apron lip and the edge of the double layer butts up against the edge of the lip, making a flat platform for the cooler
I would like to see a picture of the original brackets next time you get a chance.
Skype: shocker2000
PostPosted: Tue Aug 25, 2015 2:58 pm
http://minikingdomonline.com.au/product ... il-cooler/
Fitted as Simon described.
If you really need a picture as fitted I can crawl under my 1970 S amongst the dirt, grease, spiders and cobwebs to get one. Just let me know. :)
PostPosted: Tue Aug 25, 2015 3:08 pm
No need. That picture is perfect. I can't remember if mine has the double layer of metal or not.
Skype: shocker2000
PostPosted: Tue Aug 25, 2015 4:41 pm
here's a better view - easy once you have the part number, thanks Doug :)
