It is currently Thu Aug 14, 2025 12:24 am
Post new topic Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
PostPosted: Thu Jan 08, 2015 2:11 pm
Matt,
If you set the base advance at TDC as usually suggested, you can set any of the 7 advance points at zero or above.
However, if you want to actually `retard' the ignition ie give spark timing after TDC, you will have to set the base advance at say 10deg ATDC to allow this.
PostPosted: Thu Jan 08, 2015 2:46 pm
I've not got any turbo experience, but does the advance vary much ideally with the change in turbo boost? How does this input interract with the timing on the dizzy on a car without electronic ignition?
PostPosted: Thu Jan 08, 2015 3:25 pm
MiniVLT wrote:
mattsmadmini, I'm assuming your asking about using Accuspark Stealth Blackbox here and not to Doc's water heated manifold mod?
I'm thinking of using the Accuspark Blackbox myself for a normally aspirated setup, and for a forced induction motor it would also be ideal. Once the system is installed and basically tuned, the simplistic plug in the laptop to modify your advance curve far outweighs pulling out the dizzy to be recurved every time to want to make a change, is in my books the way to go.
With forced induction, as you are most likely well aware, you need to start taking away or retarding ignition advance once you put boost into the engine. Accuspark would be very easy to do this with, especially with supercharging as you almost have a known boost at a given RPM!
Cheers Shane
for forced induction i can recomend the Autsportslab Megajolt Lite as it has a MAP sensor and you re set your igniton advance for a given boost pressure, I have been running it on my mini for around 5 years or more without any issue as all.
http://www.autosportlabs.net/Main_Page
100% Pure A Series Turbo
PostPosted: Thu Jan 08, 2015 6:19 pm
I know someone who played around with turbo's in the dark ages and they once found a dizzy out of some car that they were able to re-engineer so the vacuum advance became a boost retarder. I believe they said it was possible to do because the donor dizzy was spun the other way to what was needed, so the mechanism was working backwards. Or something like that
PostPosted: Thu Jan 08, 2015 7:18 pm
Mick by the end of the week I will have these units in stock. (For those who want to support us Local businesses) The manufacturer advises not to use them with Ignition coils that have a primary resistance lower than 1.5 OHMS. I will be selling these units for $200 post included. Or Complete with an electronic Ignition Kit for $250.00. We also have new Coils to go with them for another $50. So for $300 you get the lot Box, Electronic Ign, Kit and Coil Posted.
"Let us remove your "SHORTS"
PostPosted: Tue Sep 08, 2015 2:32 pm
Reading the comments on this unit it seems it requires a certain amount of voltage to operate.
2 Questions...
Will the unit continue to operate ok on a car fitted with a generator where the voltage tends to drop low at idle especially when operating for example wipers and headlights?
If ever found in a situation with a flat battery (eg too weak to crank) would it be possible to roll start the car?
PostPosted: Tue Sep 08, 2015 2:46 pm
2 Questions...
If your battery is at 12.6V (not charging - just the battery) that should surely be enough. Provided that you have a decent battery and decent connections, you should be fine even when at idle where your battery may not be charging. It might be worth while to check when the black box cuts out and then we can get a better answer - but the voltage drop from just the car running shouldn't be a problem.
Roll starting - well, it's just the same as normal except you might need to roll a little faster! When roll starting you will need power to get a spark - if your battery is really, really low, rolling the car faster can provide the current via the alternator. Same thing here - you'll need to get it rolling up to the speed where the generator voltage is high enough to get the black box kicking. Or you could just jump start it :)
PostPosted: Tue Sep 08, 2015 3:56 pm
It was me that had starting problems, these have gone away since I refitted the Lucas starter.
Even at 2deg C, it starts OK.
PostPosted: Tue Sep 08, 2015 4:25 pm
I'm running a generator and it works fine. Just watch the polarity of the generator.
PostPosted: Tue Sep 08, 2015 5:17 pm
2 Questions...
1. Yes, the box needs 5 volts to operate. It does this by shedding seven of the nominal 12 volts from the car's supply. Its like making a 5 foot plank by cutting a 12 foot plank shorter. If your system is dragged down to 11, or 10, then it won't be a problem.
2. Yes it will start. When your battery is "flat", that means its discharged enough that it won't provide 100 amperes to the starter motor. If it is not a shagged battery, then as usual it will provide the approximate 5 amps for the coil just fine. The addition of the black box will only alter this value by a factor of perhaps 0.5 amperes, at worst. So 5.5 instead of 5, again, no trouble.
PostPosted: Tue Sep 08, 2015 5:37 pm
Perhaps my problem was low voltage to the Powermax module then, not the black box. Whatever, I needed 10.5V at the coil to get a spark. With the BIG starter on it, I had less than that.
It would only fire when I let go of the key, and no it doesn't do this now.
PostPosted: Tue Sep 08, 2015 5:46 pm
I would suggest that the voltage at the point you are getting the 12 volts from sags as the coil draws current. It may be there is a poor contact in the ignition. With overheads from inline ICs, it may be dropping instantaneously. You may not see this on the multimeter as it averages over a number of short sample intervals. I would split the blackbox box supply from the coil supply, or put in an ignition relay, or replace the ignition switch.
PostPosted: Tue Sep 08, 2015 6:43 pm
I think it is the ignition switch. Changing the starter has just hidden/reduced the problem.
PostPosted: Tue Sep 08, 2015 9:51 pm
Nope, not this time. I went throught this, the voltage at the starter terminal was the same as at the coil. around 10.0V with the big starter. All good clean starter cables & connections, cleaned spade lugs on switch and fuse holder, bolted connections to coil, and a new 640CCA Century battery.
Before this I suspected the switch, but it's not the problem.
Anyway, now it is fine, I can't make it happen with the Lucas starter. :lol:
[edit] The ignition switch ran the Mini solenoid as usual, which then switched the Bosch starter one. So there was no more load on the ign switch white/red wire than normal.
BTW, during this phase I bought a brand new ign switch, in a white box. :roll: When cranking, it totally dropped the ignition circuit. I took it back to the importer and suggested he might check the other 20 he had in stock.
Quality control? What's that these days? :lol:
PostPosted: Sun Sep 20, 2015 5:34 pm
Hi all,
Got a black box and fitted up but cannot get any spark. Unit powers up OK and I've edited the advance curve to std mk1 Cooper S but when I wire in the black box I get no spark? I can rewire it back to using the Pertronix ignitor directly off the coil and get a good fat spark but nothing with the black box in the mix? Having read through the thread I checked the voltage at the coil (this is where I picked up the live supply for the BB as it seemed easiest when I made the wiring loom up) and it seems to vary from around 10.2 to 10.5 volts? Could this be my problem and, if so, how do I get around it?
Thanks
Rod
Users browsing this forum: No registered users and 276 guests
