It is currently Tue Jul 22, 2025 2:09 am
 Post subject: Re: radiator coolant
PostPosted: Fri Sep 11, 2015 11:02 am
`Evans waterless coolant' is a popular one.
GR uses it in race engines, he swears by it. Motor and rad have to be empty, with NO water at all.
I still use ethylene glycol concentrate (usually Nulon) and I mix it 25%. I drain it every year or two, never had a problem.
PostPosted: Fri Sep 11, 2015 5:11 pm
Can you still get SQ36 concentrate. That's what we used in the dealership.
PostPosted: Fri Sep 11, 2015 6:05 pm
I'm a bit of a fan of Penrite 10/10ths.
This is a non Glycol based coolant (you are not allowed to use Glycol in a Superkart) so it is not slippery.
My Superkart was used every 4 to 6 weeks and was only drained every year, so possibly similar to usage to many mini users.
There were multiple materials in the cooling system, so galvanic corrosion can be a problem.
Whenever stripped down, all of the cooling system and engine waterways were in immaculate condition.
I'll admit I don't use it in my mini yet, but it is my intention to.
http://www.penriteoil.com.au/products.p ... roducts=98
Phil
PostPosted: Fri Sep 11, 2015 8:04 pm
My dad used to use soluble oil in his cooper s when he had it in the 70s as coolant he's told me try it but I don't think you can get it no more
He also used to use baby oil in the su dash pots
PostPosted: Fri Sep 11, 2015 9:58 pm
Soluble oil is bad for the hoses. As we found on my dad's FE Holden back in the 50s or 60s.
