It is currently Sun Aug 17, 2025 2:49 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Oct 22, 2015 6:56 am
Another quick question. I tested the volts with the alternator electrics connected whitch gave me 10 volts, obviously feeding back form the battery. I tested again with the plug to the back of ten alternator removed, car running, and got 0 volts. Just to confirm if the car is running, alternator turning, but not pluged into the system should I still get a volt reading from the alternator plugs? Or does the regulator need to have the plug attached to take readings and produce the the charge?
PostPosted: Thu Oct 22, 2015 7:31 pm
If the field wire is in place, and you have removed the charge wire, then you should see at least 14 volts at the terminal with the engine running. A photograph of your alternator would help.
Don't be connecting or disconnecting anything with the engine running BTW, if its not too late.
PostPosted: Fri Oct 23, 2015 2:34 pm
Thanks. I have cleaned up all the wiring and ensured there is nothing shorting etc. I will test it out tonight.
I havent been connecting and disconnecting the alternator etc. while running. Thanks for the reminder though.
PostPosted: Mon Oct 26, 2015 2:43 pm
Still no luck. This mini is doing my head in
PostPosted: Mon Oct 26, 2015 4:20 pm
My offer is still there if you need a hand.
1963 Morris 850
Users browsing this forum: No registered users and 326 guests
