It is currently Fri Jun 20, 2025 4:18 am
PostPosted: Sun Nov 01, 2015 1:56 pm
Hi all,
Does anyone run this little gadget in their remote gearbox? I was wondering if it was worth it? Does it hook in between the remote has and the gearbox itself?
http://minisport.com.au/mini-reverse-lo ... -gearboxes
PostPosted: Sun Nov 01, 2015 2:04 pm
It is a physical stop for the lever - at the flange where the plate clamps the lever into the housing.
Totally unnecessary on a road car. If you're worried about possibly trying to engage reverse in any normal driving, you should consider whether you should be driving at all.
PostPosted: Sun Nov 01, 2015 2:07 pm
Gotcha. Well, I don't drive at all - because of my eyesight, but my Fiancee found with my current rod change box it was extremely vague and very easy to miss the 4th gate. Remote will probably be a lot more direct I assume.
PostPosted: Sun Nov 01, 2015 3:22 pm
remote will be a lot more direct, it's hard to miss the gate. You can also fit a stronger reverse detent spring
though aren't you meant to lift the gearstick to get reverse on a rod change?
PostPosted: Sun Nov 01, 2015 3:38 pm
If you want a stronger lockout spring, make one from a blue or red die spring, 3/8" OD.
Red is stronger of the two, I run one. Works great.
Note if you have a reverse light switch in there you will need to make a smaller diameter plunger to fit inside the spring.
[edit] If you can only get 10mm springs (damned metrication!) grind the outside down to 9.5mm (3/8").
Last edited by drmini in aust on Thu Nov 05, 2015 5:57 pm, edited 1 time in total.
PostPosted: Sun Nov 01, 2015 6:14 pm
If you experience issues finding gears in a rod change it's because somewhere along the line something is worn out.
And a rod change gearstick shouldn't be able to move across to reverse without physically lifting the gearstick up to move it across.
So you may be able to fix up your rod change to provide clean no trouble gear selection without too much work.
PostPosted: Sun Nov 01, 2015 8:00 pm
Rodchange boxes have a bit of flat bar welded inside the shifter's bottom tin cover. The sharp corner wears off it eventually.
Only 5 mins work to bung some weld on there and grind it square again.
PostPosted: Wed Nov 04, 2015 5:36 pm
If you have a welder... ;)
Cheers, Ian
(and, No, the Moke is still a project ... getting the S back on the round has assumed precedence...
PostPosted: Wed Nov 04, 2015 7:30 pm
Cheers, Ian
I grew up on a farm, don't they all have an arc welder (including yours?) :) $99 or so at Bunnings?
Users browsing this forum: No registered users and 36 guests
