It is currently Sun Jul 27, 2025 10:29 pm
PostPosted: Wed May 25, 2005 10:32 pm
Ok, don't say one has one speed and the other has two... :wink:
Is there any difference visually? I say that because I don't know if some nut has installed a single speed windscreen wiper in my Clubby or not. It only works at one speed, and I have taken it apart and checked it all, checked the switch etc. all to no avail.
Jonathan
PostPosted: Wed May 25, 2005 11:43 pm
I believe a 2 speed wiper motor unit should have 4 wires running to it where as a single will have only 3.
Hope I got that right way round
Cheers Dat
PostPosted: Thu May 26, 2005 12:00 am
if the plug is upside down i think it will only work one speed
PostPosted: Thu May 26, 2005 12:48 am
If you already took it apart, then its real easy - have a look at the brush gear - single speed motors have to brushes, 2 speed ones have an extra, notched brush.
Plus the big gearbox wheel is different (I think double speed = 3 metal strips on the wheel) and offcourse 4 forks for double speed (unless its a later MK4+ motor where there are only 3 forks)
PostPosted: Thu May 26, 2005 7:00 am
It is possible to make a single speed motor have 2 speeds, was popular back in the `60s. What you do is put a switched resistor in series with the field? wiring. Was a long time ago.. lol. Can't remember what resistor value. This mod will reduce motor torque at higher speed, but does work.
:idea: Use a variable resistor, like my Fiat had.. :lol:
PostPosted: Thu May 26, 2005 9:05 am
I have built a small circiut to give an intermitant sweep. Just like the 'real' ones it has a knob to vary the time between sweeps.
David L
PostPosted: Thu May 26, 2005 9:33 am
I'd like details on the above two posts - original single speed motor converted to two speed sounds just right for my Traveller!
I'd also like to have variable intermittent wipers on the van.
Kinda OT, but I'll ask anyway:
I fitted two speed wipers from a Clubby to the van, using a std K headlight switch to switch them. Problem, with the park circuit wire connected, there was some sort of short. As the wiper gear passed the "park" point, the dash lights would go dim! I've tried bypassing various wires between the switch and motor, tried a different motor, but it was still no better!
Eventaully I disconnected the park wire and now run without auto park.
I've obviously miswired somewhere, but where?? :?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu May 26, 2005 11:01 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i remember my dad had one of them aftermarket intermitant wiper box's on his hd ...... memorys hmmmmmm
makka
PostPosted: Thu May 26, 2005 1:55 pm
OMG I'm a tool. I had two wires around the wrong way at the actual switch! LOL!
But while I was at it, I opened up all the switches and cleaned out all the crap inside.
[END OF THREAD]
Jonathan
PostPosted: Thu May 26, 2005 1:59 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
oh no he opened it up ............
that switch will now selfdistruct :wink:
PostPosted: Thu May 26, 2005 3:00 pm
Yeah I almost broke it. Mmm, the gloriousness of old brittle plastic!
Jonathan
PostPosted: Thu May 26, 2005 9:46 pm
It was a kit from DSE but is now not stocked - it is a Vellman Kit number P2599 but listed on their site as K2599 http://www.velleman.be/
PM sent
David L
PostPosted: Thu May 26, 2005 10:11 pm
When i get some time I'll drag out a 1 speed wiper motor and try to remember HOW I converted it to 2 speed, 35 years ago.. :?
I've still got a Fiat 124S wiper variable resistor to try. Maybe this time I'll have the first Lucas `variable speed' wipers! :lol:
PostPosted: Fri May 27, 2005 9:47 pm
if it's a Fiat, just speed up the video and the wiper speed appears normal.
http://www.users.on.net/~ashsimmonds/x_ ... lstyle.avi
Users browsing this forum: Bing [Bot] and 101 guests
