It is currently Mon Jul 28, 2025 3:11 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Feb 18, 2016 7:11 pm
sitnlo62 wrote:
I find this photo very confusing.
The fact that it is showing a radiator end engine steady bar.
To my knowledge that is not standard on a Australian Clubman GT. ( I have owned and parted out a few, Few too many I guess in years gone by)
Also the Crankcase ventilation plumbing is not consistent with an early Australian Clubman GT.
That crankcase ventilation system was used only on cars fitted with the Cast in Tappet type Block which did not appear until later in production.
I would also question that Unipart air cleaner sticker as being correct for that era.
Would like to know a little more about that photo, where it came from, very Iffy IMHO :D
Dave
It is a bit strange, I wonder what date the test was. (I wonder what the object of the test was)
When did the inner guards get the plugged hole crumple zone?
Unipart had started around that time, it might be a filter box from Parts and Accessories.
PostPosted: Thu Feb 18, 2016 7:37 pm
from what I have been told and what I've seen plugged holes in the inner Guard started in 73 which would make it a very Late GT so yes it would have the 1206 engines ( with closed tappet chest) so the crankcase ventilation system would be correct ( I know there is quite a lot of debate on this and really don't want to start it all over again :(
I have knowledge of several late GT's with 1206 engines, including mine, that have the thermostat end engine steady fitted which would appear to have been fitted from the factory. :wink:
Rod
PostPosted: Thu Feb 18, 2016 7:45 pm
Rod
Hey Rod, Did they still have the remote box or the rod-change when they fitted the extra steady?
The rod change started in 73 with the Austin Allegro in England and Australia just followed suit (oil leaks and all)
PostPosted: Thu Feb 18, 2016 7:52 pm
They still had remote gearboxes with close ratio cluster
Rod
PostPosted: Thu Feb 18, 2016 8:01 pm
To cover a few questions from above:
Here is the link to where I posted the photos on the crash test. These photos came from the Australian factory. I'll try to find out more on the history of the test.
viewtopic.php?f=2&t=85906
According to its engineering drawing the steady bar (part AYG2296) was released into production on 12/10/72. The Cars First Used On field shows YDO18 and YDO30 (Mokes) and YDO21, 22 & 23 (the latter is Clubman GT).
The four-way breather is included in the Australian Mini parts microfiche for the 1275 engine.
PostPosted: Thu Feb 18, 2016 8:22 pm
Rod
Here is a 1973 GT with the 1206 engine.
http://bringatrailer.com/listing/mini-clubman-1275-gt/
Looking at the compliance plates ADR 10b, 12, 16, 18, 21, 24 were introduced Jan 1973 so maybe the crash testing in that photo was done for those ADR's in late 1972 with a 1206 engine.
PostPosted: Thu Feb 18, 2016 8:43 pm
The PUB23 Mini parts microfiche shows the inclusion of a left hand side engine steady arrangement at YG2S8 car #1474, which is around January 1973 according to the register.
The steady bar I mentioned earlier (AYG2296) has a bend in it but I think it is used as a replacement for the clutch-end straight steady bar, not at the water pump end like we're talking here. Tomorrow I'll try to check the parts mentioned on the fiche.
PostPosted: Thu Feb 18, 2016 8:45 pm
do you ever get time to sleep doug ?
PostPosted: Thu Feb 18, 2016 8:48 pm
Yep, once all the day's outstanding questions have been answered. :)
PostPosted: Thu Feb 18, 2016 9:12 pm
YG2S8 1592 1/73 with a 1206 engine and passenger engine steady bracket.
http://www.quicksales.com.au/ad/untitle ... -701175908
P.S Are we getting off subject, I know I am. :D
PostPosted: Thu Feb 18, 2016 9:27 pm
Yep :(
PostPosted: Thu Feb 18, 2016 9:40 pm
I suppose the holes in the guards (for 73 GT's) were crash tested for effectiveness and these are the photos from it.
Although I don't know why they didn't use a cheaper model....
It is a 73 GT from the breather set-up and steady as Rodmac has said
PostPosted: Thu Feb 18, 2016 10:42 pm
So when you say 1206 is that the size of the engine ie not the standard 1275?
PostPosted: Thu Feb 18, 2016 10:48 pm
1206 is the engine prefix for a Late Clubman GT 1275.
They also had 9FXEY, 1200, 1205 prefix's.
Some info here viewtopic.php?f=45&t=90886
PostPosted: Thu Feb 18, 2016 10:58 pm
Right.
Thank you.
:D
