It is currently Tue Jul 22, 2025 6:28 am
PostPosted: Mon Sep 12, 2005 9:03 pm
Spaceboy wrote:
yeah, less power.. but the 998 is a much sweeter engine and lasts longer.
How long do you want it to last?..mine is over 8 years old and still produced the most power at the dyno day and i've done 20,000k's on it this year alone and it's not my only vehicle....it made a good 15hp than the best 998...
I know i'd take it anyday over my old 998... :?
Adam,
With any 4 cylinder inline engine the #1 & #4 pistons are up when the #2 & #3 ones are down.
So, you turn the motor over until #1 is at TDC, #2 is at BDC.
Stick a slightly curved bit of wire (coat hanger) in thru the #1 & #2 plugholes (curved so it will touch the head of the piston, not the dish) and measure the difference in length. That is the stroke. 998 is 76.2mm stroke, 1098 is 83.7mm. ;)
PostPosted: Mon Sep 12, 2005 9:19 pm
at 25HP it is most likely a 998 and I am more than 80% sure it has something to do with ignition or carburettor, both are not that costly. You can get alot of go out of a 998. Ask Kazjim!!! 8)
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 12, 2005 10:37 pm
Awsome, sounds good too me,
How would you know you got the pistons in the correct position??
Jet Red Mini K
PostPosted: Tue Sep 13, 2005 10:19 am
Umm.. well top dead centre is exactly that.... Take the head off itll help you enormously..
Anyway, you were asking prices for an 1100 rebuild/reco - I got said operation carried out earlier this year along with new UJs, gearbox etc for a nick over 4500, that was here in Melbourne. However, if your gbox is good (and providing it is actually a K gearbox too with 4synchro!!) and ur CVs and drive train are ok then you could get out of it a little cheaper.
Bear in mind however that just getting a good block bored and ready to go ranges from 1000-2000 as a starting point, and then you go from there with everything else - pistons, crank, cam etc. Plus labour of course if you're not doing the job yourself, obviously this cost varies as does the amount of labour time required.
Hope that helps, but speak to your preferred specialist to see what you can do. Man, how do u survive with 25.7HP!?
PostPosted: Tue Sep 13, 2005 10:24 am
you could always pick this up if it hasn't sold :wink:
Metro Turbo power unit brand new. Unique opportunity to acquire everything you need to build a complete new turbo power unit with factory reliability. All parts are genuine Rover or top quality parts supplied by MED in England. All machining work carried out by MED.
Block is rebored, faced, cleaned, new cam bearings. New welch plugs, gallery plugs, crank shells and thrust washers. New Omega pistons fitted to con rods. New Kent camshaft with new followers. New duplex timing chain, gears, tensioner. New turbo oil pump. New Cooper S type crank pulley and damper. New water pump & pulley. New genuine turbo electronic distributor and coil. New pre-engaged starter motor. Near new alternator.
New genuine turbo head casting with new valve guides and factory unleaded valve seats. Genuine turbo valves (sodium filled exhaust). New valve springs to match camshaft. New high lift roller tip rocker assembly, Rover alloy rocker cover with chrome nuts and new oil filler cap. Turbo fully rebuilt with new bearings and compressor wheel. New exhaust manifold, dump pipe and wastegate actuator. New turbo carburettor & inlet manifold & plenum chamber. New fuel pressure regulator. Factory ECU to control boost pressure. Near new genuine turbo flywheel and clutch assembly (lightened and balanced). New clutch plate, housing cover, release lever and bearing.
All gaskets, nuts, bolts, studs etc, crank case breather valves and hoses included. Complete new genuine ERA Mini Turbo exhaust system.
Also includes complete assembled gearbox (recently rebuilt) and brand new diff. Also transfer gear housing and gears. Asking $5000 firm. Located near Brisbane but will ship anywhere at buyer's expense. Call Julian on 07 3201 1709 or email jjg at gil dot com dot au.
PostPosted: Tue Sep 13, 2005 4:27 pm
An interesting Fact about the Mini K which i have found from a website here are the details:
Mini Deluxe Mark II K (Mini K)
Known as the Mini K, it was launched with a 1.1 litre motor.
Features included dished, padded steering wheel, changes to
the instruments and a long-life alternator.
Synchromesh was fitted to all gears. Hydrolastic suspension became
standard and the engine size increased from 998 to 1098 ccs,
power from 40 to 50 bhp (30 to 3.5 kW).
Jet Red Mini K
PostPosted: Tue Sep 13, 2005 4:29 pm
that might be at the fly, not wheels.....
PostPosted: Tue Sep 13, 2005 4:46 pm
Nailed it on the head there JAM, or is the the nail on your head(avatar)
Aaron
PostPosted: Tue Sep 13, 2005 7:10 pm
hey it's still 10 HP. :lol: Torque was better too, increased to 60lb/ft. :P
PostPosted: Tue Sep 13, 2005 10:21 pm
Aaron
more like a dick I think :lol:
I must change that pic!!!
Users browsing this forum: Bing [Bot] and 92 guests
