It is currently Mon Aug 18, 2025 6:50 am
Post new topic Reply to topic  [ 342 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 23  Next
PostPosted: Tue Sep 05, 2006 7:22 am
probably mine that im waiting for.
gess the whole of oz is against me. sulk.
YEah he mentioned the bolts to me aslo and said that the hardness was appauling. I mentioned ot him about the competition diff pins and they are the same hardness as the std diff pins but charge twice as much, they still wear out.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Tue Sep 05, 2006 7:54 pm
Of course, then there's layshafts.... some sold here from UK (made there, maybe) are about as hard as licorice.
If you can file a shaft, it is useless to use as a rolling element bearing.
It must be 63HRc at least.
Thankfully we can get Oz made ones that are made from good stuff and properly heat treated... :wink:
PostPosted: Wed Sep 06, 2006 9:58 am
Mini Update 3
My crank is cracked!!! :cry: :cry: :cry:
Yes folks, Graham suspected that it may be cracked as it bent itself back quite easily after not budging several times. We sent the crank off to Spiro and Graham asked him to crack test the centre main before grinding and sure enough, apparently there is a huge crack around the center main! :shock: :cry:
This is perhaps why the crank was not balancing properly. It may have been in a big blow up in it's previous life...
Oh well what a waste of good work, but lucky we tested it!!! :shock: Could you imagine if we just whacked it in?
Luckily I have another spare small J 000 000 cross drilled EN16 crank 8)
More news later...
PostPosted: Wed Sep 06, 2006 4:17 pm
Oh brother dont talk about bent cranks!! I just went through this with a rebuilt motor with a bent Cooper S crank.
Lucky for me the shop rebuilt the block again with a new crank even though it was 5 months after the warranty was over though but I had only done around 150km on the engine!
Thanks to Dr Mini for the diagnosis of the engines knocking noise because a bhusted crank was the last thing I expected or wanted to expect :shock:
PostPosted: Wed Sep 06, 2006 7:10 pm
I must admit that was one of the first thing I got checked of my Cooper S motor was the Crank...Bad luck chong but atleast you did find out and time wasted Gilly :twisted:
Chong your doing a great job Mate :wink:
PostPosted: Wed Sep 06, 2006 7:27 pm
Cheers Jim :(
Yeah the rebuild was going too good :lol: I needed a good dissapointment to keep me inline :wink:
PostPosted: Sat Sep 09, 2006 8:48 pm
Hello all,
Not much to update this week as I sent the spare crank off for grinding. I still managed to spend all day at grahams helping him out taking apart a Nb racing S engine. Learnt lots and had nots of fund doing it!
I will spend this week cleaning the block as I have had no chance at all tlast week.
More updates next week! 8)
PostPosted: Mon Sep 11, 2006 9:47 am
Lucky I found another crank instead of buying your spare one off you :) Sorry to hear about the other crank, it's a shame but I'm sure it will all work out.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Wed Sep 13, 2006 1:57 pm
Lillee wrote:
I will goto Hare and Forbes at North Parramatta this weekend (near Graham's actually :) ) and buy myself a dial gauge and magnetic base set 8) About time I invested in one :oops:
have a look here maybe:
http://www.transquip.com.au/product.aspx?ID=4519
PostPosted: Wed Sep 13, 2006 2:07 pm
Good spotting mike! that looks pretty good. Cheers
PostPosted: Fri Sep 15, 2006 10:22 am
Mini Update 4
The spare crank has passed the crack test and is being ground today! Yay! thank goodness :lol: Thanks to Spiro of St George Crankshafts in Seven Hills 8)
More updates tomorrow.
PostPosted: Sun Sep 24, 2006 12:08 am
Latest Update
I really must apologise for missing out on updates last week and this week. You can all pretty much say that the build has been stalled because of the cracked crank. As you know my spare crank has been sent off to be crack tested and ground. Well it has come back looking like new, is now 010 mains and 010 big ends.
I had a bit of trouble with bearings as I had ordered 010 mains originally, then changed them for 020 mains (as I thought the cracked crank was going to be ok at 020) and then had to chang them again back to 010 mains! Morale of the story is, don't buy bearings until you know you have a crack free, freshly ground crank! :wink:
This week at Grahams
Welll finally all the crank issues are over, well almost all. When the crank was sent to Spiro for grinding, he noticed that one of the big end journals had picked up a bearing at some stage and picked up metal that had welded itself to one of the crossdrill holes :?
Anyway Graham managed to drill it out and balance the crank. He is undecided about whether we should replug the hole or not with a new plug... he says it is unecessary for what I am doing with it (road car). We will decide this later...
The other thing "wrong" with the crank is one of the counterweights has been severely angled off with a big grinder. This was "factory" balancing. They didn't have time to worry about making cranks look nice, they just took to them with a huge grinder and took out what they needed to in one pass :shock: Subsequently there is ALOT taken out of one of the counterweights. Graham has managed to balance the crank and there was not much needed to be taken off the crank to blance the entire crank. Graham says although the counterweight grinding is not ideal, it is ok for what I am doing (road car). If it were a full race car he would build the counterweight with weld and grind it back and balance again.
All in all I am happy with the results of the crank. It does look very good.
Dry Assembly: Take 2
Today i managed to try assemble the crank and rods with pistons to check the deck hieght. To my surprise the middle 2 pistons were 8 thou above the deck and the outer 2 cylinders were 4 thou above the deck. Graham says this is acceptable and we can get away with it as I don't plan to rev the engine past 6500rpm anyway. This was a relief as 010 thou or more meant taking the pistons off the rods and machining them. *phew*!
Well that was all for this week unfortunately as it was a short day. Sorry about not having photos as I know you all love pictures :lol: but I promise to have more rivetting pictures soon showing my head on the flow bench, assembly of the head and complete assembly of the block, crank, pistons and cam.
This could happen before next weekend 8)
PostPosted: Sun Sep 24, 2006 8:27 pm
Update 24 September
As promised I will update everyone with pics! (I know how much you guys love pics :wink: )
Final preparations
How exciting!!! this is it! I've been waiting for this for week!
I started by scrubbing the insides of the block including oilways. I used Graham's long handled brush and got all the dirt out of the oilways, bearing feed oilways, main galleries and the block, crank and rods and making sure it was entirely spotless. I then ran them through 15 mins on the hot washer. They all came out spotless.
All clean and ready for assembly
The new uncracked, ground and balanced crank. Note that the dull finish is due to acid dipping and hot washing.
The cleaned block
Note that I have an older 1100S block, you can tell because it has a gaping hole in between 2 and 3. This was removed in later 1100S or so called GT blocks. Graham ground around the hole so that there are no sharp edges or burrs.
Final Block Assembly
I then began to assemble the crank and rods with the new Duraglide bearings. I used bearing saver assembly lube on both the bearing surface and the journal surfaces. Graham reminded me to use LMM grease on the threads and under the heads so that they would torque down properly.
Graham then warned me that the bolts may bottom out at full torque, in particular the centre main bolts. He must be a psychic because sure enough the bolts were bottoming out! the hole is deep enough but the thread bottomed out. There are really 3 options, tap it deeper, cut the bolts shorter or use hardenned washers to space the bolt enough so that it doesn't bottom out. Graham just happened to have a stash of ARP hardenned washers (as you would :lol: ) and all was sweet.
Crank End Float
Using my old thrust washers we inserted them to check the crank end float was 003 thou. Ideally it would be good to be about 5-7 thou clearance. We started by checking the flatness and some of the trust washers where varying in thickness by 1thou along the length! Using wet dry and a pane of glass I took to thinning the thrusts down a further 1 thou each. The total float is now 005 thou. Perfect 8)
Pistons and rods assembly
I then installed the rings onto each piston by following the very clear instructions contained in the hastings box. I used a special piston ring expander tool to put the top 2 compression rings in. Now instead of using a ring compression tool Graham has a special ring compression pipe thingy! It is a bit of steel machined up with a shamfered top and is perfectly the size of +060. Basically using WD40, the piston is pushed into the tool which compresses the rings. The whole assebly is then slid into the cylinder and the piston is pushed into the cylinder. It works so well I managed to install all 4 pistons in no time at all. I got to get myself one of these! :wink:
Graham's Special piston compression tool
The finished product!
All that is left to do with the block is to paint it!! Now you must all be wondering what colour I have chosen to paint this hot engine of mine :P I have decided that since Lillee is relatively stock looking (no flares) and is a red car she would look hot with a stock looking S engine :D I know some of you don't agree (like how boring) but I think the metallic green will look good against a silver gearbox and silver clutch cover.
I will attempt to do this during the week at home before installing the cam and assembling the rest of the engine. Until then, may all your dirty hands smell like WD40 :lol:
PostPosted: Sun Sep 24, 2006 9:49 pm
good to see it together Chong. must have taken you about 5 minutes after i left on Saturday :D
now you are ahead of me again :cry:
 Post subject: Endfloat
PostPosted: Sun Sep 24, 2006 10:15 pm
Chong....interestd to know if you and GR used anything special to check end float :?:
How much force is needed on the end of the crank.....I recently found one that had about a millimetre of endfloat....that was easy to demonstrate by grabbing the nose of the crank and pushing backwards and forwards.
Did you use a dial guage or feelers :?:
Great work with reporting on the engine build :D
Users browsing this forum: No registered users and 118 guests
