It is currently Sun Jun 22, 2025 10:28 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Nov 07, 2006 9:56 am
here you go..
one honda civic...
one rotary...
people put honda engines in minis....
rotary engine in a honda.....
a bit of maths.... a bit of cutting and..
PostPosted: Tue Nov 07, 2006 10:10 am
more links
http://www.ausmini.com/forums/viewtopic ... 9&start=45
http://www.ausmini.com/forums/viewtopic ... c&start=15
PostPosted: Tue Nov 07, 2006 4:34 pm
Al Munday wrote:
It was raced but it was never legal. 8)
From memory, I think the Gulson car ran a 13B and Hewland. Sports Sedans back then had few rules 'cept original floorpan and roof. It had to stay fwd. Amazing car though for the era!
The problem was the layout of the engine, gearbox and differential had to be set out in the same orientation as the original engine. This was the rule that led to Geoghegan running two Hewlands in his Monaro and a change to this rule led to the end of the Gardiner/Grice Corvair. The rotary mini with a Hewland does not run the driveline in the right format to be legal.
PostPosted: Tue Nov 07, 2006 4:54 pm
so from reading the other topics cushway posted....
12a seems the way togo?
if so.... ur up for a new subframe.... brakes......d/shafts....etc
would much cutting of the body be required....
PostPosted: Tue Nov 07, 2006 6:31 pm
it was pushing on the edge of being legal when he built it but by the 80s it was totally legal as the rules were changed to allow a new generation of cars to be built like the Saabs and Camiras to be built from front drive to rear drive, Paul was only not allowed to run it in Supermini racing because they had a rule where the originally gearbox case had to be used hence Warwick Agustins car had the toyota driving through a mini box,
Jon
PostPosted: Tue Nov 07, 2006 6:47 pm
Jon
How would a rule that allows front wheel drive cars to be converted to rwd make any difference? :shock: It would have been ok if it was converted to front engine rear drive but it was still not legal as a front wheel drive under the rules.
PostPosted: Tue Nov 07, 2006 7:01 pm
1100
By the fact that the rules allowed the engine and gearbox configuration to be changed, the types of cars bing built had a new set of rules laid down in the Cams manual for the type of layout/config for building cars. If they had not allowed the gearbox engine config to be changed the Saabs, Calibra's, Camira's,preludes and the like woud not of been built without the gearbox beside the engine just like a east/west config, once changed for them the mini was totally legal as gearbox location became totally free
Jon
PostPosted: Tue Nov 07, 2006 7:05 pm
Yeah... you are quite right. Ahhh memories.... remember the Corvair "apparently" had sandbags over the rear wheels in the "wet". That could be one of those myths too, but Gardner did some amazing stuff.
62 Saxon Green 850
Clubby van
PostPosted: Tue Nov 07, 2006 7:10 pm
feralsprint wrote:
1100
Jon
I would recommend reading the CAMS manuals over the different years just to see what the rule book does in fact say. 8)
PostPosted: Tue Nov 07, 2006 7:17 pm
1100
not only did I have to read the cams manuals as a scrutineer for all those years, Cams issued the car a log book to race with it in this configuration and it was raced without being logged in NSW, Vic ,QLD and SA, as stated in my previous posts it could not run in the Supermini series because of the gearbox rule but it had no problem as a sports sedan
PostPosted: Tue Nov 07, 2006 7:32 pm
feralsprint wrote:
1100
A scrutineer, that explains why you can't read a rule book. :lol:
Tappets was logged a few times with that car, I was at Amaroo when it was logged once. A chief scrutineer had it in for the car.
CAMS used to issue log books to any car. You did not even have to have a car to have a log book! I know of a few cars that had multiple books so that if it was logged in one book they would just use another book.
PostPosted: Tue Nov 07, 2006 7:56 pm
feralsprint wrote:
1100
1100
:lol: And I know who the scrutineer was, it was Lance and it had nothing to do with the way the car was built, he just hated mini's and one of his favourite things was to write up every mini for the flares or anything he thought he could get away with cause we srutineers know how you car builders and owners read the rule book :lol:
Hey you at least had to have a picture of a car to get a log book :D there are still a few cars out there running on there 8 or 9 body after an accident running on an old log book :D shhhssssssssssssssssss no one would be doing that now would they
It was not the first mid engined FWD there was the mini with a 179 holden engine, went like the clappers in a straight line but refused to go round corners
PostPosted: Tue Nov 07, 2006 8:06 pm
Wasn't Lance. 8) I better not say who it was. :?
It was only illegal because of the gearbox, if it used a gearbox with the diff on the other side of the gearbox it would have been legal (or more legal!)
PostPosted: Tue Nov 07, 2006 8:16 pm
would you two get a room.... :P
PostPosted: Tue Nov 07, 2006 8:22 pm
1100
Oh well i better go and and make 75% of the sports sedans running around illegal with you reading of the rules :lol: I am sure they will all be happy :D
The car has been sold and run two different owners to my knowledge since those days without the configuration being changed and has been in a garage in Vic for many years now.
Jon
