It is currently Sat Aug 02, 2025 12:34 pm
PostPosted: Sun Mar 11, 2007 10:46 am
I am putting my 6" speakers under my rear seat in Leila. but there are two ways that i am thinking about doing it.
1st way is to put them in a box under the seat, so that i can put them in the corner, which will mean that i can still have space to store shite under the seat
2nd is to just put them on a flat board and block up under the whole seat (the way that most people seem to do it.
My biggest concern either way is that people may kick the speakers whenthey get in out/ when they sit down, and also that with just a big flat board they look a bit uggher.
just after some feedback frompeople that have done either way, on the practicality of both ways
thanks
chris
PostPosted: Sun Mar 11, 2007 11:12 am
I made this up and fitted these Kenwood 6 by 9's...
But then i found these 7 by 10's.....
I cant carry passengers in the rear so i aint got any dramas. Just make sure people are aware that they are there b4 they get in....
PostPosted: Sun Mar 11, 2007 11:58 am
Die Die Die!!
just buy some speakers that have the mesh cover on them... i use responce 80watt RMS 6x9's theyre good bang for the buck at about $130 a pair
PostPosted: Sun Mar 11, 2007 12:03 pm
I had mine like Hanra's, sounds ok. That was until I stripped all the audio stuff in favour of power to weight ratio 8)
PostPosted: Sun Mar 11, 2007 12:07 pm
Chong, with all that plastic that speakers are made from and the tiny magnets used, it wouldn't have made any difference, besides, would it gain you that much? Being your all about power to weight, why don't you run it down the qtr mile, i'd be interested to see it go up against enki's automatic :lol:
Aaron
PostPosted: Sun Mar 11, 2007 12:54 pm
Aaron
chong, dont forget to take the street map out of you car when you take it down the 1/4 mile, :lol: :wink:
i have the same setup and it sounds awfull, i made a box so that whole space is one big box, the bass is good because it viabrates through the car but it is no where as crisp as other systems, i think its mainly to do with the seat in the way and deadens the sound,
mind you it does sound good with the front seats out,
PostPosted: Sun Mar 11, 2007 1:07 pm
Die Die Die!!
i forgot to mention as well... its a bit muffled if you put it under the rear seats... and its alot muffled if someones sitting in them..... i moved mine to the parcel shelf.. and have never looked back... definatly better there soundwise...
PostPosted: Sun Mar 11, 2007 1:28 pm
_666_ wrote:
i forgot to mention as well... its a bit muffled if you put it under the rear seats... and its alot muffled if someones sitting in them..... i moved mine to the parcel shelf.. and have never looked back... defiantly better there sound wise...
If there's holes there in the first place I agree. Best would be to create a box per speaker and angle them up by sliding a piece of MDF up between the box and the speaker. Just cut it so its 1/2 a circle then screw in that way you'll have the sound aiming closer to your ears. Also better sound and way less muffling then if you used the space under your seat, as the box.
Bass reverb and distortion will happen a lot more if you used that bigger space as the speaker works best with a smaller volume/capacity. For a 6" speaker I'd be wanted no more 12L and if memory serves me correctly the space under a seat of Mini is far more then that even if you account for both speakers, with a total max volume of 24L which is massive and is the recommended size for a 12" sub.
What ever you do though don't buy plastic boxes, make them yourself from MDF or some other similar wood you'll get a deeper bass and clearer mid and high frequency sound, or I can for you. Either way give me a buzz if you need a hand. Good luck with it mate.
PostPosted: Sun Mar 11, 2007 1:52 pm
Die Die Die!!
if your not looking at cutting holes in the parcel shelf.. (which is more than understandable) then perhaps get some speakers that sit on the rear shelf in its own pod.. i also did that before forking for the 6x9's
PostPosted: Sun Mar 11, 2007 1:54 pm
I've thought of using small speakers already in boxes with brackets
Like these:
David L
PostPosted: Sun Mar 11, 2007 6:37 pm
Chris, I had one in JAM, and it was nice, but yes rear seat passengers do knock them a lot.
As soon as JAM became a daily driver, it was THE most stupid thing to have. That space under the rear seat is PRIME REAL ESTATE in a daily hack, and I ALWAYS have something stashed under there in my current hack.
In JAM I fitted speakers in the bottom of the side storage bins, mounted in MDF boards cut to the internal shape of the storage bin. Bloody ripper!!! :mrgreen:
At the end of the day, it all depends whether your DOOF DOOF is more important than rear passenger leg room and / or storage (junk) space.
PostPosted: Sun Mar 11, 2007 7:41 pm
So if i mount them on the rear parcel shelf (which i am leaning towards, as i do use under the seat alot) will it have any effect on sounds, as they will not be boxed as such when they are sitting in the self open in the boot?
PostPosted: Sun Mar 11, 2007 7:47 pm
Most modern speaker sets sold for car fitment are designed for baffle mounting, ie into the rear parcel shelf or doors.
Not little boxes.
I did build a pair of 4" ones for the boat, I mounted them in Jaycar plastic boxes 1/2 filled with speaker wadding.. They sound OK, but not much bass (didn't want that when fishing...) :wink:
PostPosted: Sun Mar 11, 2007 8:23 pm
the boot acts as one HUGE speaker box, and your sound will be quite good IMHO, but I am no ICE expert :lol:
PostPosted: Sun Mar 11, 2007 8:27 pm
yer boot helps heaps to get max sound
under the back seat gets a fair bit muffeld
Users browsing this forum: ken@miniauto and 86 guests
