It is currently Sat Jun 28, 2025 11:00 am
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jul 10, 2007 9:16 am
Mate, proud of you.
Perserverance pays off!!
Let me know if Qik Brix Racing can be of assistance.
Keep us posted.
Tricky
PostPosted: Tue Jul 10, 2007 9:26 am
Well done Goffy ,this will be a very potent mini when it's finished , sort of on the lines of the Metro 6R4 only not 4wd . Anybody know if anything like this has been completed and registerred in Australia before ?
PostPosted: Tue Jul 10, 2007 9:34 am
thanks guys
PM sent tricky
I've only heard of a rwd bike engine in WA somewhere but i think it was only a race car.
PostPosted: Tue Jul 10, 2007 10:48 am
nice one goffy, keep it up. im keen to see the rest of this build
PostPosted: Tue Jul 10, 2007 11:37 am
Awesome. And its in Brisvegas too! Tricky and I might have to come out for a sticky beek and provide collaborative support. Tricky for the doing, me for the visualising and creating more doing for Tricky.
PostPosted: Tue Jul 10, 2007 11:59 am
haha thatd be great, i better tidy my garage its quite bad atm :P
PostPosted: Tue Jul 10, 2007 4:21 pm
I think you are giving me too many ideas for my next project :lol: :lol:
Congratulations.
Dan
PostPosted: Thu Jul 19, 2007 10:28 am
Hi
thats great progress
what brakes & hubs are you using?
PostPosted: Thu Jul 19, 2007 11:20 am
73GT wrote:
Hi
thanks 73
im going to be using Metro Turbo Vented Brake conversion kit on the rear with 4 pot calpiers and adapted for the handbrake, adjustable lower arms on the top and bottom of the upright plus some coilover shocks. Up front will be the 4 pots supplied by zcars since im using their front subframe kit
PostPosted: Thu Jul 19, 2007 1:57 pm
Have you priced up getting one of their subframes over here?
Maybe we could do a "group buy" as I'm sure one of your kidneys has to be worth at least two frames. So you donate a kidney, get two front subframes and I'll buy one off you.
PostPosted: Thu Jul 19, 2007 2:20 pm
hahaha well im hoping it to be round $2500, anything less would be a bonus. Im going to ring them up on monday so if anyone wants to get one too pm me and ill ask for combined shipping. For people who are unsure what it looks like:
Also i nicked this from my proposal to the engineer explaing what it was
The tubular front subframe from z-cars (Figure 1.1) is designed to eliminate bump steer. It is 10kg lighter than the original Mini front subframe and includes mounting points for the radiator and aluminum fuel tank (Figure 1.2). Included are inboard aluminum rose jointed adjustable shock absorbers which are operated by pushrod lever from the wishbones. Double wishbones again rose jointed and adjustable for caster and camber by means of left and right hand thread rose joints and connectors. The whole kit is powder coated and nickel plated on the metal parts. Also the kit fits the original mounting points at the top for the subframe and down near the driver and passengers feet. Instead of the original 2 bolt fixing, the subframe has a 10 bolt fixing adding to the stiffness of the subframe. It has an integral pedal adaptor (Figure 1.3) for the accelerator to enable the mounting of a straight throttle cable under the car from front to back and then pulling on the original cable through the bulkhead using he original Mini pedal. Under the radiator at the front is room for a dry cell battery to be fitted.
Zcars also make a front subframe for a series engines in the front that look pretty much the same and are good cause of the stiffness plus coilovers and eliminated bump steer.
All of this info i got from zcars.org.uk
PostPosted: Thu Jul 19, 2007 3:06 pm
I'm sure you[ve already though of it but be sure to tell them that you've got a mk1 mini (note the differentiation in the mounting).
PostPosted: Thu Jul 19, 2007 7:10 pm
thanks for the reminder JC. i need the 2 bolt fixing one
PostPosted: Thu Jul 19, 2007 10:09 pm
Yeah nice Goffy, cant wait to see the parts in the flesh.
PostPosted: Fri Jul 20, 2007 2:25 am
very trick looking stuff 8)
