It is currently Tue Jul 22, 2025 2:04 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Nov 03, 2007 12:45 pm
he might want to plug his dissy back up or he wont be going anywhere too quick,
or is he running that edis thing
PostPosted: Sat Nov 03, 2007 2:56 pm
No dizzy in this one. 8)
PostPosted: Sat Nov 03, 2007 5:11 pm
It has a Motec ECU running it ;)
PostPosted: Sat Nov 03, 2007 5:15 pm
I think Buztoy's talking about the dizzy that's filling the hole in the photo's 8)
PostPosted: Sat Nov 03, 2007 5:18 pm
Yea - it's a distributorless ignition - you can see the coil packs to the left of where the dizzy is.
PostPosted: Sat Nov 03, 2007 5:56 pm
how does it sense when to ignite, is there a sensor on the cam, would this mean that spark adv would kick in at a sertain rpm rather than a sertain vacume measuremant,
hasn't ever been done with 5 port has it? :cry:
PostPosted: Sat Nov 03, 2007 5:59 pm
Yes it has, Benjamin's turbo 1132 runs it. You program it. :wink:
PostPosted: Sat Nov 03, 2007 6:00 pm
Dont they run a crank angle sensor?
PostPosted: Sat Nov 03, 2007 6:01 pm
Yes, on Ben's there's a trigger wheel on the harmonic balancer, I machined the balancer to fit it.
PostPosted: Sat Nov 03, 2007 6:36 pm
so the computer on bens 1152 only controls the ignition firing, it doesn't control anything else like injection or fuel pressure
PostPosted: Sat Nov 03, 2007 6:45 pm
No injection, it has a real SU carby... so it makes good power. 8)
PostPosted: Sat Nov 03, 2007 7:05 pm
you just challenged the only rule of being a weber man,
PostPosted: Sat Nov 03, 2007 7:11 pm
Well an SU is just easier to setup on a turbo for blowthrough.
Only because they made Metro turbos in UK.... :lol:
It's been done with a Dellorto but takes lots more stuffing about.
PostPosted: Sat Nov 03, 2007 11:45 pm
Archangel007 wrote:
is that a genuine ute?
MK1 tailights??
Yes, those are the taillights used on pick-ups until '78 (and not on any saloons).
 Post subject: hi
PostPosted: Sun Nov 04, 2007 4:47 pm
here are the tail lights on my old 1980 austin mini pick up
and here are the tail lights on my 1974 modified pick up
