It is currently Sun Aug 17, 2025 11:34 am
 Post subject: Stripped thread on hub
PostPosted: Tue Mar 03, 2009 12:00 pm
I have a disc brake hub with a stripped thread where the bottom ball joint screws on. Anyone successfully repaired one like this?
Pete
PostPosted: Tue Mar 03, 2009 12:04 pm
Toss it away, they are cast iron. NOT steel... :x
PostPosted: Tue Mar 03, 2009 9:02 pm
I is a mookenik
lol i repaired mine last nite :D just get a thread file and it should be 20mm then just start filing a new thread. worked for me and its good as new.
PostPosted: Tue Mar 03, 2009 9:08 pm
This space for rent
Not the balljoint pin Joe, the actual hub itself, where the big 1-1/2" inch nut screws down. Like Doc says, if that's stuffed the hub is stuffed...
PostPosted: Tue Mar 03, 2009 9:10 pm
I is a mookenik
ohhhh dam yep ur screwd...
Joe , two different things , you were talking about the end of the ball joint where the nut screws on weren't you ? Peter is talking about the thread on the hub where the ball joint cup screws onto . If the threads damaged on the hub the ball joint can seperate from the hub under load (read that as in a hard corner) and fold the wheel up under the guard so isn't worth fiddling with .
PostPosted: Tue Mar 03, 2009 9:12 pm
I is a mookenik
yeah i thought he was talking about the balljoint stud itself lol.
PostPosted: Tue Mar 03, 2009 10:25 pm
I figured it was toast. Just thought I would ask in case someone smarter than me had found a way to fix one.
Thanks for the confirmation.
Pete
Users browsing this forum: No registered users and 378 guests
