It is currently Tue Jul 22, 2025 1:54 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Apr 01, 2009 6:08 pm
How do you get the distributor drive back in the block and engaged with the cam?
With #1 at TDC the skirt of #3 is in the way so how do you line it up with the crank rotated enough to get a clear line of sight - and then how do you do it?
Getting frustrated here :x
David L
PostPosted: Wed Apr 01, 2009 6:12 pm
turn the motor either way about 10° from TDC. :wink:
PostPosted: Wed Apr 01, 2009 6:22 pm
make sure you have a long bolt screwed in to it
PostPosted: Wed Apr 01, 2009 6:39 pm
I'm doing both - but don't seem to be able to get the thing to lock in and engage the cam - which way does the turn in relation to the crank - do they both turn anti-clockwise?
David L
PostPosted: Wed Apr 01, 2009 6:49 pm
Are you holding ya tongue right?
PostPosted: Wed Apr 01, 2009 6:52 pm
It will turn clockwise as it goes in. :wink:
PostPosted: Wed Apr 01, 2009 8:21 pm
Wombat,,, hold your tongue slightly to the left & fit it with your eyes closed... feel it slide in nice & gently,,, you know ,,, just the same way you fit your,, er ,,,ar,,,um ,,, OH!!! sorry that won`t be allowed to be said on this forum hey? :-)
PostPosted: Wed Apr 01, 2009 8:27 pm
Got it in - went right in and the outer retainer slipped right in fully. Before I removed the bolt I thought I'd give it a turn to see if it rotated
The (*&$%^ # 3 piston hits the drive shaft and won't go any further :evil:
Guess I'll be giving Mr GR a call in the morning
David L
PostPosted: Wed Apr 01, 2009 8:38 pm
With those pistons you have to machine the body of the dizzy driveshaft down to 8mm or so. :wink:
Aaron found the same prob today.
Pic of modded shaft in Vizard's book.
Easy job.
PostPosted: Wed Apr 01, 2009 8:46 pm
Hmmm he's talking stroked engines to clear the crank - this is the skirt of the piston hitting it will it still help?
If so it will be in the mail to you tomorrow :wink:
David L
PostPosted: Wed Apr 01, 2009 8:47 pm
Yes it's the same problem. Skirt of RE piston is maybe longer than a normal 1100 one, it's also .100" bigger diameter..
PostPosted: Wed Apr 01, 2009 8:53 pm
Easy job.
Yes, it is an easy job but I wouldn't want to try it with an old Myford and a piece of high speed steel! Those shafts are HARD!
Dave
PostPosted: Wed Apr 01, 2009 8:56 pm
jeez, aren't you glad you found that now and not when you hit the starter!
PostPosted: Wed Apr 01, 2009 8:57 pm
Easy job.
Dave
You may find it hard to believe but I did just that, in my Myford. 8)
But I'm used to this, I reface Mini valves the same way.
PostPosted: Wed Apr 01, 2009 9:07 pm
Did you think it was hard material?
Maybe the one I did was an exception it was as hard as hell!
Dave
