It is currently Tue Aug 19, 2025 12:59 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Feb 18, 2010 7:02 pm
That engine and head does not look good at all!!
1970 Mini K
PostPosted: Thu Feb 18, 2010 8:54 pm
Here's my effort, and yes that is the head of the inlet valve in the top of the piston.
Steve
PostPosted: Mon Feb 22, 2010 9:18 pm
ahh not good, how was the crank and block after that effort?
1970 Mini K
PostPosted: Mon Feb 22, 2010 10:07 pm
Holy crap... how does damage like this occur?!
Copper 4 lyfe!
PostPosted: Tue Feb 23, 2010 3:16 am
Crank was fine and block cleaned up at next oversize. Due to dropped valve, due to broken roller pin in the roller rocker :shock:
Steve
 Post subject: Thats Awesome!
PostPosted: Tue Feb 23, 2010 4:04 pm
You hear all these stories bout when you see them it's another thing!
What was that Steve, the k?
PostPosted: Tue Feb 23, 2010 4:23 pm
Here is a double row bearing blowup in a client's moke
http://www.youtube.com/watch?v=ho0a5XXoXq4
-Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Tue Feb 23, 2010 4:24 pm
This is what happens when you lose control and smash into a traffic island.
Wasn't me honest!
PostPosted: Tue Feb 23, 2010 4:35 pm
Here's another one I have. This is what happens if you dont fold over the locking tabs on the bolts securing the main gearbox bearing.
The bolt comes loose and rolls around in the sump till it gets wedged between the diff gear and the sump. It put a hole in the sump casing and the diff gear "machined" the bolt down. I was reversing down the driveway then Bang!. I couldn't go back any further so drove straight back into the shed to investigate.
PostPosted: Tue Feb 23, 2010 5:10 pm
I don't have any pictures, but a little honda v-twin engine, 670cc 4 stroke that i pulled apart yesterday had seized one big end, broken the other off the crank, broke both rods in half, cracked the block and smashed the bottom of the bore sleeve out of shape. not to mention broke off the skirt of a piston.
It's going to get a rebuild though
PostPosted: Tue Feb 23, 2010 5:41 pm
Ouch!! Those gearbox failures look NASTY!!
Things that make you go HMMM!
1970 Mini K
PostPosted: Tue Feb 23, 2010 5:49 pm
Mods rock!
Nah, these none of that, they're all trophies :!:
PostPosted: Tue Feb 23, 2010 5:57 pm
Yea true hey :)
1970 Mini K
PostPosted: Mon Mar 01, 2010 9:41 am
Here is one for you,
Don't leave rags in gearboxes! we just pulled this apart for a client!
Rag on the oil feed pickup filter
Rag in hand next to the oil feed pickup feed filter, you can see how the oil suction has bent the filter up.
what one should look like!
Why anyone would leave a rag in a gearbox has me astounded!
Ph: 08-8177-1275
Skype: minisport.au
PostPosted: Mon Mar 01, 2010 9:48 am
So as to soak up the oil before it leaks out of the gearbox! :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: No registered users and 310 guests
