It is currently Wed Jul 23, 2025 8:53 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Apr 05, 2005 11:07 pm
will do. is the primary gear shimmed because i found a broken shim in the clutch housing and if so what should the clearance be(any ideas on why it would break). and if not where did the thing cum from
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Tue Apr 05, 2005 11:26 pm
There is a thrust washer behind the primary gear, of various thicknesses to adjust end float which should be .0035-.0065".
These things are fragile and do break if end float is excessive.
Also check for wear on the `C' washer at outer end of gear. Buy a new washer if you can.. :wink:
PostPosted: Fri Apr 22, 2005 8:28 pm
parts are on back order so nothin can be done for 5 to 6 weeks. but i added sum forged high lift rocker to it also.
PostPosted: Sat Apr 23, 2005 1:07 am
Just the one or a whole set?
PostPosted: Sat Apr 23, 2005 6:52 am
He's ordered a set. :wink:
When I ordered mine they were out of stock (as usual) it took 6 weeks to get them.
PostPosted: Sat Apr 23, 2005 10:51 am
I hope they are available when I am there! I priced the gearbox kit as separate parts and it's well over double the price!
Lillee - 1969 Morris Mini K
PostPosted: Sat Apr 23, 2005 2:45 pm
:idea: Ask them to put it in a bag and charge you kit price! 8)
PostPosted: Sun Apr 24, 2005 3:10 am
yea try that - they'll say no. They make the kit, they put it all together - yet they wont do it on a special order.
Users browsing this forum: Bing [Bot] and 80 guests
