It is currently Wed Jul 23, 2025 9:06 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Apr 05, 2005 11:07 pm
will do. is the primary gear shimmed because i found a broken shim in the clutch housing and if so what should the clearance be(any ideas on why it would break). and if not where did the thing cum from
PostPosted: Tue Apr 05, 2005 11:26 pm
There is a thrust washer behind the primary gear, of various thicknesses to adjust end float which should be .0035-.0065".
These things are fragile and do break if end float is excessive.
Also check for wear on the `C' washer at outer end of gear. Buy a new washer if you can.. :wink:
PostPosted: Fri Apr 22, 2005 8:28 pm
parts are on back order so nothin can be done for 5 to 6 weeks. but i added sum forged high lift rocker to it also.
PostPosted: Sat Apr 23, 2005 1:07 am
Just the one or a whole set?
PostPosted: Sat Apr 23, 2005 6:52 am
He's ordered a set. :wink:
When I ordered mine they were out of stock (as usual) it took 6 weeks to get them.
PostPosted: Sat Apr 23, 2005 10:51 am
I hope they are available when I am there! I priced the gearbox kit as separate parts and it's well over double the price!
PostPosted: Sat Apr 23, 2005 2:45 pm
:idea: Ask them to put it in a bag and charge you kit price! 8)
PostPosted: Sun Apr 24, 2005 3:10 am
yea try that - they'll say no. They make the kit, they put it all together - yet they wont do it on a special order.
