It is currently Wed Aug 20, 2025 4:09 am
PostPosted: Wed Feb 15, 2012 8:41 am
Mike_Byron wrote:
I did an inventory check yesterday - I have at least eight two piece flywheels. If you know someone going past near here let me know and we can work out something in terms of a pickup.
Mike
Let me check my holiday itinery i know im staying in dubbo for a few days and i also plan to visit canberra at some stage. So i may be able to pick it up and deliver to canberra. This wont be for 2 or 3 weeks though :/
PostPosted: Wed Feb 15, 2012 9:13 am
I have CNC Machined lightweight flywheels finished now if you`re interested
PostPosted: Wed Feb 15, 2012 9:27 am
I'm sure there are hundreds of flywheels in Canberra - talk to someone in the ACT mini club
PostPosted: Wed Feb 15, 2012 9:35 am
infact there monthly meeting is tonight.
Meet 7:30pm 3rd Wednesday of the Month
Deakin Sports & Social Club, Deakin
Surely someone there would have one :D
PostPosted: Wed Feb 15, 2012 9:29 pm
Yep - I've probably got a flywheel or 2 lying around surplus to requirements if needed....
Ken.
PostPosted: Mon Apr 16, 2012 10:35 am
I ended up tapping some new threads and it eventually came off without destroying my puller. I'm not really sure how this balancing business works - do I just get the flywheel itself balanced, or the whole flywheel+clutch assembly balanced together? Can anybody suggest a good place in Canberra to do this?
Harry
PostPosted: Mon Apr 16, 2012 3:09 pm
You usually bolt the flywheel to a balanced crank, balance the flywheel first (by drilling holes), then bolt the backplate on with the straps and balance that.
Then bolt the diaphragm on as well and check balance again. Try all 3 possible positions and choose the least out-of-balanced one.
If you are really anal you can perhaps drill a few small holes in, but it's so light it won't be far out anyway. :wink:
I did one recently where someone had bolted the backplate on and drilled a dirty big hole 24mm in it alone, to balance it AND the flywheel. Almost drilled right through it. I binned that backplate, I've seen what can happen.. they are grey iron and not real `bendable'. :lol:
PostPosted: Mon Apr 16, 2012 5:50 pm
Harry
You could always give Chris or Ian at Berco a call. They did all the machining on my last engine build and it's still in one piece.
